Kitchen sink drain knackered
21 Feb 2021
The black pipe where the kitchen sink water flows has become detached. I smeared filler around it...it's been knocked loose.
The photos attached show the outside and the pipework under the sink.
Is this a big job?
Could a builder fix all this from the outside?
Filler was never gonna hold that mate, waste pipes flex with hot water and knock loose instantly. Any local plumber can sort it in an hour or two. They'll just core out the old stub cleanly, slide through a fresh length of 40mm solvent weld pipe with a slight fall into the outside hopper or gully, clip it securely to the brickwork, and solvent weld a new trap adaptor inside under the sink. Cheap fix for materials, mainly just an hour or two of labour.
This is also well within any half competent builder/handyman remit, rather than specifically needing a plumber.
Working only from the outside? I should have mentioned there's hardly any thread outside, the new pipe doesn't slot into anything.
Is this a big job?
Could a builder fix all this from the outside? View attachment 427204View attachment 427205
As said, could easily be fixed, but with solvent weld this time. SW can be trickier, but it's just a case of gluing together the least accessible bits, prior to fitting them in position. You can assemble the components and do a 'dry run' first.
You don't need a plumber or a builder particularly, but a plumber is more likely to have SW glue on his van.
We (extension builders) are always having to re-hash wastes when we build extensions, so we do carry the right gear.
Ideally you need to work from inside and out so a new continuous piece goes from the trap outlet through the wall into the first elbow.
Any repair from outside alone will be another bodge.
so that pipe would need sawing off and replacing on the inside?
