hi guys, i want to change my kitchen spot lights from the current 12v dichroic halogens to l.e.d spot lights. can i just change the bulbs or do i need to change the transformers and fittings. thanks
The existing lighting not quite atrocious enough for you?hi guys, i want to change my kitchen spot lights from the current 12v dichroic halogens to l.e.d spot lights.
What do the people who make the LED lamps say?can i just change the bulbs or do i need to change the transformers and fittings. thanks
Really?There's a good chance that the LED lamps you're looking at are 230v GU10.
Your current lamps are 12v so the transformers would need to be taken out of circuit.
Also, either the lampholders would need changing to GU10 or the fittings need changing.
One would assume not.Have you seen the light output from some of the LED lamps currently available?
thanks for that. how much light will i lose with l.e.d lights. i have 15 down lighters in the kitchen all 50 watt
750W just for the kitchen, nice.
And that doesn't tell you that 2" recessed downlighters are not designed to light rooms?thanks for that. how much light will i lose with l.e.d lights. i have 15 down lighters in the kitchen all 50 watt
