Kitchen tap removal advice please
The loose ring connector you linked to goes inside the fitting a bit. If the male fitting won't take a pipe with a nut and olive then it probably won't take the connector either. You could try it though and see it it fits.
Ah I see what you mean. I bought the part to try it. I haven’t tried it yet but assume you mean the bit that protrudes above the washer in this image. This would need to fit inside the cold flexi hose male end. I will need to dismantle the tap to try this. That’s my next step.
