Kitchen temp wiring
16 Feb 2007
Hi
We are in the process of having kitchen fitted. We are using the existing supply (that was for dw & wm) which is on its own 4mm radial with a 32A MCB for new multi oven (3.7kw) with a 20A double pole isolator.
The plan is to have the combi oven (3.6kw) on its own supply however, for the short term would we be able to supply both the multi & combi ovens from the 32A circuit (would have both isolated with 20A DP).
Hope this makes sense and any help appreciated?
Thank you for the replies.
Hob is on its own supply (32A) MCB
