OK, I now understand what you were saying. Thanks.To fit an LED costs the price of the LED and control gear so in the example I fitted which was 5 foot then cost £17 for the tube and should I have been buying the fitting then to get same light it would require a double fitting so total was around £36 compare with a single fluorescent with a HF ballast at around £18 it cost about double for original fitting to fit LED with the same lumen output i.e. compare like for like. ... At replacement time LED will cost £34 to replace and the fluorescent £3.4 actually likely fluorescent will cost less than that. Simply as with fluorescent your not replacing control gear and with LED you are.
As I recently wrote, the one missing bit of that price comparison is the relative lifespans of fluorescent and LED tubes. In theory, LED tubes are meant to have a lifespan of around 40,000 hours, whereas fluorescent tubes usually claim lifetimes around a quarter to a third of that - so, in theory, one would have to replace fluorescent tubes three to four times more often than LED ones, thereby decreasing the (very) long-term price difference.
Mind you, this is all a bit hypothetical. At, say, a couple of hours use per day, 40,000 hours amounts to about 55 years, so I doubt that (m)any of us would be around to worry about replacement cost if it really lasted that long! ... and, of course, available technologies for lighting will almost certainly have changed dramatically long before 55 years has passed!
Kind Regards, John
