    Dismiss Notice
Kitchen wall cabinets - bracket (why so big !)
Discussion in 'General DIY' started by NottmTony, 23 Aug 2016.
  1. NottmTony
    NottmTony
    7 May 2015
    38
    Thanks Received:
    Nottinghamshire
    Country:
    I'm fitting a Hygena (homebase) kitchen cabinet.
    The wall brackets they hang on to (which I assume are quite standard) are quite wide and at first glance look like they give you a lot of tolerance (horizontally) - however they have to be lined up just inside the recess at back of cabinet so in reality they have no tolerance whatsoever really.
    So why are they so wide ? To make them stronger / able to support heavy loads ?
  2. Burnerman
    Burnerman
    7 Feb 2008
    23,139
    Thanks Received:
    4,499
    Northumberland
    Country:
    With these plates being somewhat bigger than they would need to be gives a greater span for any rawlplugs drilled into the wall. Drilling masonry holes very close to each other often gives breakthrough.
    John :)
    • Thanks Thanks x 1
  3. Sponsored Links
  4. NottmTony
    NottmTony
    7 May 2015
    38
    Thanks Received:
    Nottinghamshire
    Country:
    Ah - now that would make sense - especially when I am going to use 10mm wall plugs !
  5. Burnerman
    Burnerman
    7 Feb 2008
    23,139
    Thanks Received:
    4,499
    Northumberland
    Country:
    Good luck with your project!
    For me, its Fischer plugs and Spax screws every time.
    John :)
  6. Sponsored Links
  7. foxhole
    foxhole
    14 Mar 2006
    17,980
    Thanks Received:
    2,060
    Kent
    Country:
    10mm wall plugs are too large, 6-7 mm are ideal.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
