kitchen wall paint- Eggshell or soft sheen.
Agreed with the mat paint, I have tried diamond matt 10x mat or whatever they call it and they are all rubbish when it comes to wiping marks off.
The kitchen I used the jhonsons eggshell and everywhere else in the house I use dulux soft sheen.
I also find with the mat that it catches dirt in the air and you can see it in the corners at ceiling level. Or a build up above a radiator - very faint from dust rising from the heat. Matt is nasty stuff used by builders to mask bad plastering.
Soft sheen was a great go between paint in my opinion
It seems like all the trendsetter have decided durable matt or tough matt or wipeable matt wasn't cool anymore so now people in the main seem to want it
I think soft sheen is a far more durable paint than any of the so called modern matt paints and a lot of the bathroom and kitchen paints are 4 on a 10 scale compared to silk so fine by me
Not so much soft sheen about these days it seems so if I can't get any I use a low sheen bathroom or kitchen paint
If not people will end up painting their walls every other year
Yes I found the dulux soft sheen not easy to get hold of. I would use the johnsons egg shell again and it looks the same as the dulux soft sheen to me but a little expensive for general use everywhere but would be good in the hall stairs and landing.
I thought you didn't want to use eggshell ?
Soft sheen is made by johnstones and leyland as well as dulux
And a lot of bathroom and kitchen paints , advertised as specially for kitchens and bathrooms ......are actually just soft sheen
Johnstones do a sheen rating on their emulsion paints these days I think , on the back ?
I wouldn't bother with dulux paint personally
Thanks for that. that goes with my thinking but goes against JohnD's thoughts. when you talk about the finish (using the the foam roller) are you referring to the finish via the roller (orange peel effect) or the actual paint finish/sheen?
If you look at an ordinary brown or white egg , eggshell paint is said to have that sort of finish
A dull shine I suppose
Obviously that finish will depend on ones eyesight , the area painted , the light and how good the paint is
Nope that's not me - you are getting mixed up a bit. It was JhonD saying it was hard to clean - clearly he knows nothing. I gave a link to the eggshell I used in my kitchen its good stuff.
I have used Dulux Trade diamond matt several times. It is an odd beast. Without Floetrol/etc, the first coat wants to go on very thick (even over existing emulsion). The second coat glides nicely over the first.
I do however disagree with your suggestion that matt emulsion paint is only used to mask bad plastering. Granted, it is more forgiving of bad plastering than emulsions with a higher sheen level.
In the past, I have used stoopidly expensive ultra matt paints on very, very long ceilings to mitigate the risk of the sunlight highlighting minor bows in the ceiling. On the upside, any dinks left by the kitchen fitters could be touched in without any halo effect (that I could see). Impossible to keep the paint clean though.
ARRRGGGH
I had just decided on eggshell, went into Johnstones to discuss the colour codes and they suggested cleanable matt.
I had a look on some of the reviews and it seems pretty good.
As you say Matt is very good at hiding bad plastering etc. as our house nearly 200years old it doesnt have the best condition walls so we could do with as much covering up as possible lol
So to throw a new factor in the mix!
We have a tiny bit of skirting visible (its actually dado rail)along with some pipe box work and a ratty back door these are all bare wood finished with water based varnish. Mrs T has suggested that they, along with the radiator would look nice painted in the same colour.
I was thinking I could use some acrylic primer (any recommendations?) and then the wipeable Matt?
Really trying to convince myself that Matt would look better and be ok.
But I am guessing that from a practical point ist should be eggshell?
I would use a proper primer over varnish , not just acrylic
Zinser Bin, 123 , Crown PX3 or 4 etc
Thanks for that, I have already bought the primer undercoat (leyland acrylic primer/undercoat) the varnish is water based (if that makes any difference) I will sand the wood to key it
If it's a shiny or semi shiny surface then leyland acrylic primer won't be suitable ....the paint system will break down in time
You need a special primer that enables paint to grip to it .....zinser BIN , Zinser Cover Stain, Crown PX4
If you use Zinser BIN or Crown Px4 then after 2 hours you will be able to apply 1 coat of your ordinary primer ...leyland ....then after this has dried .....your paint to finish
But if you just apply ordinary acrylic water based primer like the leyland you have ......the following coats will flake off
You need to SEAL in and PRIME that glossy surface .....that's done with a coat of those primers I have listed
Thanks for that. out of thee Zinser bin and Crown which would you advise? I know the Zinser needs meths to clean it but see that the crown is water based
