Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Thanks for that. out of thee Zinser bin and Crown which would you advise? I know the Zinser needs meths to clean it but see that the crown is water based
I have been using BIN for years. When I first started using it, I used cheap throw away brushes but the finish was subpar. As time went on, I discovered that you can use household ammonia to clean the brushes. Meths merely thins the paint. Ammonia completely breaks it down completely (very quickly). I now happily use £20 brushes when applying BIN. I pour the ammonia into old jars, dip the brush in the ammonia, agitate the brush and rinse it in a sink. I then put the lid on to use it further down the line. Absolutely no residue is left behind in the sink.
Thats what I went for in the end. It doesnt seem to cover as well as Zinser, but is much easier to use.
I put on 2 coats just to be safe and then will do 1 or two of the primert undercoat.
