Knocking through a chimney breast for range cooker
17 Jan 2007
Yorkshire
Hi
Im wanting to knock through a chimney breast to make room for an 90cm range cooker, Would it be possible to easily knock this through on a victorian property? Im not sure how you would know the construction of the chimney without making an opening.
Would you please give me advice on how to start this project
thanks
Andy
the chimney breast is likely to have some foundations for the side brickwork and none for the frontage, though it is likely that a hearth slab will be present.
the sides will be 9" masonry and it is likely there will be either a lintel or a curved iron and header brick support at about 3 or four feet up from the floor.
removal of the plaster work will reveal a lot. :wink:
Thanks noseall
I was thinking that i would knock the plaster off and reveal what was behind it, would i need building regs to look at any enlargment of the hearth or would a competent builder be able to do it for me without worrying about building regs?
PS if it helps, there isnt a cellar under that particular chimney breast.
Thanks noseall
you will need lintel but the condition off the inside off the chimmney can also cause you probs expecially cooking food beneith it
Make sure you get the chimmney swept unless you like black globs of carbon all over your food when you boil anything.
Pete
