MY RING MAIN RUNS UNDER THE WORK TOPS ON THE WALL WITH NO CONDUIT. I BELIEVE THIS IS NOT SAFE & WHERE SHOULD IT RUN ?
________________________________
lynda, moderator
Sorry for lack of detail (& shouting) I have 6 double sockets as an extension of an existing ring main. Both cables (2.5 twin & earth) is buried vetically in plaster to the first socket. It then travels under the work top 250 - 300 mm from socket horizontally on the surface of the wall to the subsequent sockets. Dishwasher & washing machine are plugged into sockets mounted inside the back of kithchen units 250mm from the ground, the cable at this point is not attatched to anything.
If I do need to replace the circuit should I run new ring in ceiling above mounted to the joists & drop down to each of my outlets
I assume that it is both cables that go round under the worktop or is there two cables to the first socket and then only one cable that loops round to the other sockets with no return?
Re the cable route itself, there's nothing wrong with the cables being under teh worktop and going vertically to the sockets. Its untidy but (assuming the cables are not buried) its not wrong. The cables must be clipped to the wall to give them support and protected from heat, damage or other external influences.
Thanx for advice I feel much more comfortable now. Re the cable the sockets are all connected corectlly as a ring main although the last socket has a spur to an adittional socket, the hob extracter (5amp) and the outside light which I do not no how to get around.
