Does anyone have any opinions/experience of using Kuterlite comp fittings on mdpe? I'm aware of the advantages of Philmac type fittings, but there is a specific reason why I'm considering using Kuterlite. I really want to know if Kuterlite does a good competent job.
The Kuterlite body doesn't seem to be very deep, the distance from the end of the pipe to the olive is only a few mil. Do they hold on the pipe OK? Also does having a copper/brass olive cutting into the pipe give any problems? I will have one joint underground and one above ground, that's the one that's likely to be manipulated, pulled about or occasionally kicked. Cheers.
