La-Co Cool Gel
7 Jul 2008
Bedfordshire
Has anyone used this stuff and is it any good?
http://www.screwfix.com/search.do;j...THZOSFFQ?_dyncharset=UTF-8&fh_search=cold+gel
I need to do some pipe jointing approximate 6" underneath a modern plastic/fiberglass bath. I will have a flame mat between the work area and the bottom of the bath, but obviously that is only 12" square so I wondered if I should give the bottom of the bath a spray with some of this too?
soldering under the bath has never been an issue for me, i would suggest that you should just be very careful, tidy soldering very rarely needs anything more than a heat mat, don't rely on anything other than that and a steady hand, if you are unsure get a pro in to carry out the work
Ok cheers.
I have done plenty of soldering and have no intention of waving the torch around like a mad-man, I was just concerned about the heat coming up from where I was working perhaps affecting the bath.
Will just go with the heatmat then :)
Thanks Gordon, it's good to know that it does actualy work should the need arise :)
Fingers crossed for the weekend :)
