Labels for Wall hang Storage bins
9 May 2021
Hello
I have brought some storage boxes from
The range, that belong to a wall mounted system. I didn’t get the whole kit, as I wanted to put the storage boxes where I would most likely to be needed.
I don’t think I can get labels for these boxes, and I am having to create my own, I will then get most of them professionally printed when I next need to get replacement signs, notices and awareness ID cards made.
So basically I want to know if I can get pre-cut labels that will fit the storage boxes.
Storage box in question. - mine are black.
Example of the pre-cut labels
Extra info not required for this post, but may give a better insight.
So, I have a dozen, (plan for more), storage bins that are meant to be wall mounted via a kit. Of which for the last year or so, I screwed them into the wall of my shed/workshop area, but I couldn’t take them off the wall. I have spent the last year looking for a way to hang them that wasn’t too expensive.
I tend to get distracted easily, but specially lately, especially as I have had another surgery on my leg and I am taking a lot more morphine, with my autism, and reported ADHD, I somehow end up reading about a world war 2 battle that both German soldiers and American soldiers fought on the same side as allies from trying to find out if I can get labels for the storage boxes.
I use similar at work, lin bins.
I just use a dymo label maker (available very cheaply now) to make labels and stick them on the front.
That works very well.
Wording has to be custom because you are the only person that knows what it needs to say, so the hardest task is identifying what it contains and wording it as short as you can to fit on a label.
The mounting appears to be a french cleat type (I think) so if you want to mount them you would need to find the matching board.
Or make some battens with the appropriate slant on the back side so they fit.
I currently have a storage system from Aldi, 8 similar bins and 8 draws in the middle, with a large draw at the bottom.
I'm slowly filling them, labelling them.
On the bins I made 3D printed labels for those that have a specific item in them and not random chucked in stuff :)
LOL at the last sentence... I often go down rabbit holes too.
I always used a dymo 210 when I did a little of labelling at work.
You can buy them used via eBay or £70 or so on Amazon.
If you buy the heavy duty labels they last ages
There are plenty of label makers on Amazon for under £40.
Take your pick, it's the cost of replacement label cartridges that may decide which you go for so check those out too.
Hello,
Regarding the label machines I do have one, it was my Nans… a Brother P-Touch 1005.
Regarding the labels that I can make at home, if I can get a pre cut printable A4 sheets then I can print them off, but I can’t seem to find the size or the pre cut paper.
I am currently writing by hand, then using a glue stick, I then stick them onto Amazon packaging cardboard, but this isn’t going well. It’s why I am here today, either that or I am struggling to stick the labels from nans machine into the slot and/or/other problems with text size, layouts etc.
I use a website that makes signs, labels, nameplates, badges using aluminium, plastic, steel, wood, brass and more. Once I know exactly what is going to be stored, I will create little labels made out of plastic.
Ideally a small cheap 3D printer would be ideal for future use.
Regarding the hanging of these type of storage containers, as I didn’t buy the kit, as I want them where they will be needed most, I had thought about buying the kit and cutting it down, I also thought about somehow making French cleat brackets, but then I remembered I had used some flush mount brackets, and maybe they would work. So I brought a few, but these had a rounded top, so the storage box wouldn’t stay level and just slid off.
So I looked around for the same idea but maybe a different application, hoping I would find something that would work, and I found something that is near perfect. I am not sure how well they sit on the brackets (depth wise). I found kitchen cabinets wall hanging kits are a perfect fit (I took a storage container to the store, took a bracket and a did a “dry fit”.) I just don’t know if the containers are fully seated on the brackets.
Anyone know what I could use the other “end” of the brackets?
These are the type of brackets that I found, a set of 10 in the pack, I know the brackets are sold without the other end, but I found packs of 4, but it works out more expensive. 57p for each bracket (including the other end) so £1.14 each, compared to the brackets sold on their own being £1-£2.49 each.
Click here for the bracket type I brought.
If you go down the 3D printer route then you can certainly make your own brackets easily.
They have to be within the max dimensions of the printer but it's certainly doable.
There are already loads of models on makerworld.com for bins and french cleat brackets etc.
So you may be able to find an already made model file.
I'd use PETG for the plastic as it's stronger than PLA, although ABS would be better (ABS needs an enclosed printer).
Not sure what you mean by the other end of the brackets?
The bottom? the containers just hang on the bracket against the wall, the bottom is not supported.
(overfilling with heavy stuff can make them easily fall off).
As you already have a label printer why not go for that? Get some tape from Amazon and print your labels.
No need to overcomplicate it, no need to go to the extent of finding precut slide in card stock to print on - you have the solution (or your nan did) lol.
Just cut up some card and write the contents on it and stick it in that slot at the front, the one that's designed to take a contents label.
If you use avery labels, there is a downloadable template that works. Pretty sure it works on word.
I used to use metalized sheets that were umpteen lines down and I think 5 across.
They were to ID equipment with individual numbers plus our logo etc.
They were laser printed.
