Hello,
Wondering if anyone can help. I have just bought a laminate floor (dark in colour) and if at all possible I want to avoid using scotia. However, I don't want to remove the skirting.
I've been looking into flat beading, but I can't find the right colour to match it. The online company I just spoke to said that because flat beading is attached to the actual floor that it can look tatty when the flooring moves as it comes away from the wall. Is this the case? Or can you suggest any good stores?
If I have to use scotia does it would to use white scotia when using a dark laminate floor so it's less noticeable against the skirting?
Any help would be very welcome!!!
