Hi - I'm about to lay some laminate flooring in my living room.
Along the long side of the room where I plan to start laying the laminate, there is a gas fireplace with a hearth that projects out into the living room by about 40cm and is about 120cm wide. The laminate will obviously go around this hearth.
My question is: do I start laying the laminate where the hearth protrudes into the living room and fill in behind to reach the wall, or at the wall and cut around the laminate hearth (both short ways and length ways) when I get to it?
The first method would mean full-width boards past the hearth but having to scribe in the ones at the wall. The second means I have to scribe-in the "long side" boards around the hearth to go around it, and I'm not sure if that would make the joining of these boards tricky?
Any advice gratefully received.
