Laminate in same direction as floorboards...
28 Mar 2011
Conwy
Morning all
Currently decorating our lounge, a room roughly 17.5 feet long by 11.5 feet wide. Planning to lay laminate because we have a dog who likes to attack carpets, for some reason or other. The room has four inch T and G floorboards; its in good nick and level, so I don't plan to lay any levelling boards. However.. whilst I know that you're not supposed to lay the laminate boards in the same direction as the floorboards, given the layout of the room and the fact that the longest wall runs in the same direction as the current floorboards, if would be much easier cutting-wise and appearance-wise if I break that rule.
Given that these are 4 inch boards and laminate boards are, I'm pretty sure wider than that, if I use a decent underlay then is laying the laminate in the same direction as the boards a sound plan, or one fraught with danger? I have laid laminate before, but on a concrete floor that was levelled with plywood.
Thanks in advance
I don't see a problem with it if using an underlay. But the general rule for laminate is lay with the short edge facing the light to stop the window light showing up the length joins.
Thanks for the response. I think I'm best laying parallel with the longest wall because for one thing, it means far fewer cuts.
Until you reach the other wall and then you will be making full length cuts instead of shorter width cuts --- wont you ?
And you only cut the board once as the offcut is the start of the next row - unless you need to stagger differently like I try to do and not have a join right at a door threshold or the most likely foot tread area
I've got lots of spare time, and I intend to do plenty of "dry laying" before I settle on a final plan, thanks.
