Hello again. Thanks to those who have provided me with good advice over the past months. I am looking for any views you may have on the advice I have been given by a local flooring company.
Background:
About 3 months back I added a conservatory to the rear lounge of my
house. I now have one through room (roughly 26'x12'). The lounge floor is made up of 8x2 18mm flooring sheets and the conservatory has a concrete floor. I am happy that the concrete floor has dried out. There is no condensation or other signs of moisture. The conservatory is not South facing and willl not get full sun/heat in the Summer therefore I have decided to have a laminate floor laid.
The laminate I am looking at is by Balterio and is a 9mm board with the 4way v-groove, not cheap but hopefully a good quality board. The fitter has been to see the job and the 2 different sub floors.
There is a difference in level between the old and new floor, not a
noticeable step but more a gradual slope of upto 10mm from the edge of the concrete running away towards the middle of the original lounge. I hope I have explained myself clearly here.
He has suggested:
Laying the board type sheets in the original room (to raise the level)
and then cover the whole area with a standard underlay with a built in dpm for concrete floor - laminate on top and then I will finish the job by fitting new skirting (all old skirting has already been removed).
Does this see seem sensible or could I expect problems in the future.
Cheers
Background:
He has suggested:
Cheers
