Hi peeps, i have removed a gas fire and brick hearth from my fireplace and will be installing a modern 'all in one' style one. I'm not sure whether i should lay the laminate wood flooring first and go all the way up to the wall, then sit the new fireplace etc on top OR fit the fireplace first and cut the flooring up to it leaving the need for nasty edge trimming?
I'm hoping that answer a is acceptable so it can look nice and neat although any advice welcomed... maybe if i cut it just under the new hearth?
Regards,
Joel.
Regards,
Joel.
