Laminate worktops
22 Feb 2010
Shropshire
I am trying to find some laminate kitchen worktops in bright colours. Every site I check has "80 colours" but when I look they are all, in fact, brown or grey. I know that I could have some made if only I could find a manufacturer in this country.
Can anybody help me....please..... to find a supplier of coloured worktops, or a manufacturer that will make me one?
I think this may be what you are looking for:
:twisted:
Hepful Fred! to a new member too!
OP, try reposting this question in woodwork/carpentry, you might get a sensible answer. Might. :roll:
Aw ok, twas maybe a tad harsh. As its not the norm, a coloured worktop will undoubtedly be bespoke which will mean £300 or so per length for a laminated jobby, if the OP is still interested I'll find a few suppliers. You could always go Corian but then it'll be ££££'s!
I have tried John Porter and BGN so far. They both said they could do it but JP quoted £800 a length - oh, I wanted it wider than the standard 900mm - and BGN haven't replied after 2 weeks and several phone calls.
Thank you, Fred - if you can suggest anyone else I'll take the contract off your dog....
I looked at Corian but it isn't robust enough. I do a lot of cooking and don't want to start using trivets.
I didn't think to post in Carpentry and woodwork because worktops aren't wood.....
Do you mean wider than 600mm? Thats the standard! Its time to start approaching shopfitters or bespoke furniture manufacturers eg http://www.shopfitters.org/MemberList.asp?L=1 but I'd be surprised if you're not into £800+ territory anyway. You won't find a standard oversized worktop in an unusual colour off the shelf.
Corian is much more robust than compressed chipwood with a laminate on top[you kitchen worktop] and a trivet should always be used on laminate worktops as they are not robust enough to withstand great heat without risk of blowing.
You could approach a 'manufacturer' like Bushboard. They probably won't sell to you direct, but will provide samples and tell you where to buy from. I haven't bought from them for some time, but they used to make tops up to 1200mm deep (the maximum size laminate is made in).
As for price, I would expect to pay between £60 - £300 per lenght depending on quality and sizes.
No laminate worktop producer will ever give you a guarantee for putting hot pans on them although most laminate manufacturers will tell you the maximum temperature they will withstand (not allowing for the glue to the chipboard under of course !)
