    Dismiss Notice
Sealing gap between laminate worktop and laminate upstand
Discussion in 'General DIY' started by Bobthebuilder95, 9 Jan 2020.
  1. Bobthebuilder95
    Bobthebuilder95
    5 Nov 2019
    46
    Thanks Received:
    Country:
    I have installed a laminate worktop in our new kitchen and have a matching laminate upstand to install. However across the 2.6m length unfortuantly thr worktop is out by roughly 3-4mm and the upstand isn't completely flat and is out in thr wrong direction causing a 6-8mm gap at one end.
    What is the best way to fill this? Or is it worth trying to screw in from below to 'pull' it into line with the worktop? Or just colour matched silicone? Or fill with something then silicone?
    Many thanks
  2. Sponsored Links
  3. foxhole
    foxhole
    14 Mar 2006
    17,992
    Thanks Received:
    2,064
    Kent
    Country:
    Both should be installed flat and level.No gap .
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
