lamona ceramic hob t1713
23 Nov 2011
has anyone experience there lamona rings going off, brings the water to the boil then turns off, other rings stays on and some dont even stay hot,another ring get to a mild temp and does not get hot
this is a brand new hob????
Contact Howdens customer services, if it is faulty it will still be under warranty>
What model is it, does it come with a child lock, where you can change settings?
Each ring will have a thermal limiter (to protect the glass from over heating).
Sounds like the calibrations are wrong on the limiters.
As said if its under warranty contact supplier.
Gas hobs don't need thermal limiters to stop their pan supports from overheating.... :wink:
thanks guys,,,,to true i have a gas hob and oven and it brilliant, just got a frustrated family memeber. wirest thing is that there is not information in the manual regarding the rings etc
Didnt know it was gas.
Even so there will still be thermal limiting device to stop the ceramic breaking.
Had it been electric, I would have been correct. I may still be
Only trying to help.
