Is there any reason why I shouldn't put both a surface water/land drain pipe and a foul drain pipe in the same trench?? They are going to different outlets but in the same general area and from the same building.
The building inspector for one. I'm not an expert but the problem with larger gravel could be ending up with too many voids in the fill and excess settlement of the pipe- if you're on a shallow fall then you could end up in real bother with a low spot. I wouldn't chance it myself- lot of work to correct any problems that show up down the line.
I've seen plastic pipes bedded on the wrong stuff, worst I've seen is something pressing into the pipe, trying to, but not quite piercing it. It was prabably a slate or something very sharp.
20mm would work but if building control refuse it then it would be a pain to swap.
If building control aren't involved and you have a load of 20mm to get rid of, chuck it in!!
