We've got a large bathroom mirror 2.5m wide by 0.8m high, 6mm thick.
It's secured to the wall using these:
http://www.vola.com/Gb/Products/Accessories/T20
And on part of the back there is a heat pad:
http://www.screwfix.com/p/heated-bathroom-mirror-panel-410-x-580mm/77859
It's been up in our bathroom for over 2 years. I noticed some discolouration at the edge at the rear - black spotting - which I think is probably some water damage. It is safety-backed but when we bought it, I wasn't aware foil-backing was recommended for bathrooms.
If you've got this far, thanks. here's the exciting(!) bit:
It's cracked - a vertical line upward in around the area of the heatpad.
Any thoughts on why this might happen? Although it didn't happen in my presence, apparently no one had been pressing hard on it or anything. The pad may have been recently on (comes on with light) but not for any extreme amount of time.
Am about to bite the bullet - with foil backed this time - but it would be careless to make an obvious mistake twice ...
