Large crack
3 Apr 2008
Wiltshire
I have a large crack above my front door, see pic. I want to repair it before decorating my hall but not sure how to go about it. I could easily fill the crack with filler but i know it wont last so what I want to do is to knock the plaster all off and start again. Any ideas as to how I should go about it would be most helpful. Thanks in advance.
When you tap the undeerside does it sound hollow?
Have you got another pic taken further back so I can see the extent of the crack & where the ends are?
It extends the width of the door and its hollow underneath thats why I thought it was a waste of time to try and just fill the crack.
Just looking at the picture what I believe has happened is the crack has opened up due to shrinkage of the plaster on the lintel & the lump of plaster below the crack has delaminated; if it’s an older property its likely to be concrete. If there was a crack in the blockwork or a crack in the mortar joint below, it will always return unless it’s sorted out properly but it looks to be directly over the lintel (assuming it’s got one!) & not where the lintel meets the brickwork. If so, the crack will only be plaster deep & providing the lump of plaster is not actually loose, you could try raking out a fairly deep “V” groove along the crack & filling with a flexible polyester filler; it may work or at least you could try it first. The only other alternative is to remove the plaster completely, apply a new base coat & then reskim to blend in locally but if you’ve not done this sort of thing before, it may be too much for you; it will be difficult to get a decent finish let alone an invisible repair.
I would agree with what Rich'd says and remove the loose plaster from the lintel area. Once the blown/loose plaster has been removed and the area prepared/PVA'd, I would bed on, across the lintel (with dabs of multi finish) a length of "Expamet" corner bead, flush with the surrounding plaster level,and when the dabs have set, plaster over the lintel area with bonding plaster and multi.
Roughcaster.
