Large rendered garden wall with no capping
3 Oct 2006
Hampshire
I have seen a number of walls locally that appear to be rendered on the sides and the top, this seems to give nice clean lines and I have a large garden wall that I would like to do the same to (9" hollow concrete block with a top course of dense concrete blocks laid flat, about 10ft tall).
I have a family member who has experience doing rendering (I don't), he has suggested I look into self coloured options from a maintenance point of view but unfortunately hasn't used them himself.
From looking around I assume I need plastic or stainless beading, but the self coloured options are still a bit of a mystery to me? Do I have to get in an experienced contractor or can I get this bulk delivered and mix and apply it myself with help etc.. If I go for a more traditional render and paint combo will it stand up to the weather on the top with the right additives? (and what are they)
If anyone could give some advice on where to look and the pitfalls etc. I'd really appreciate it.
best regards
Trevor
I know what you are talking about, and iv'e rendered such garden/boundary walls over a timber frame or masonry background.
And they can certainly give a pleasing rounded shape.
Unfortunately, that was in a warmer climate. Over here, for me, there are too many issues of rain and frost for an uncapped top edge.
Even with a good shedding profile, moss and debris will build up and trap moisture.
For what you've got, why not give it a go - use plastic beads where necessary. Catching the scratch coat just right helps.
I prefer a smooth rubbed finish but there are options.
Why not use concrete coloring in the water, dilute to taste. Experiment, and try to avoid having to maintenance paint.
just picking up on something there, you mentioned concrete colour - is that a third option? I assumed self coloured came premixed?
