Hello All,
most logical place to post this in my mind but, I'd appreciate the mods moving it, if there is a better section for it
Bushnell Yardage Pro took a dip in a freshwater lake on Saturday.
I removed the battery, took it apart, and left it to dry for two days on the radiator.
I have bought a new (9v) battery, put it back together, and tried it.
It works, but only "sort of".
Normal operation should be:
look through the eyepiece, and view the target;
press the little button, to "range" the target (at this point, the LCD overlay on the eyepiece comes on, with a crosshairs on the target, and a yardage number to said target);
after 30 or so seconds, the LCD overlay auto-shuts off.
Current operation is that, all of the time that the battery is connected, the entire LCD display is on (crosshairs, the range displays as 1888 - i.e. all of the numerals fully illuminated, battery "low" indicator on (2 x brand-new batteries tested, on multimeter).......)
I'm hoping it's some sort of temporary short somewhere, perhaps a drop of water on the internal of the "on" button, rather than something terminal.
The "on" button is a flat piece of clear polythene-looking stuff, with four tracks on a clear ribbon, leading to the PCB; I can't dismantle the button, to see if it has any obvious shorts (or is even jammed in the "on" position").
Any ideas on the way forward?
TIA
TIA
