Just bought the latest heatbank from gledhill i have at the moment a semi gravity primatic cylinder is it just a straight swap
Primatic cylinder is fed from CWSC so not sure about the "semi" bit...![]()
How many you fitted Dickie????A Primatic cylinder is a single feed indirect cylinder, sometimes fed from a header tank.
Only indirect until the bubble bursts..
The heating system is filled via the same cistern which supply's the hot and cold down services..
Whatever you do don't pull the boiler stat phial in order to clear an airlock..![]()
Are you saying i am making this up Dan !! the semi gravity system was used from the 1960,s to the 90,s the boiler heats up the hot water cylinder by natural convection it has one hallway stat no MV,s if you check out the honeywell site you will see the original layout i,m not talking schit obviously you,ve never seen one.
