Early Victorian house. A section of a lath and plaster porch ceiling has collapsed due to water ingress. The source of the leak was identified and dealt with last year, but large cracks appeared in the ceiling a few months ago, and sagging, and finally the collapse of an area about 3'x2'. (The porch itself is about 6'x5'.) Clearly the nibs had failed, and indeed in the worst section, the laths themselves. I suspect the ceiling had been subject to the water ingress for a long time before the leak had become apparent (when water dripped through the corner of the ceiling after a particularly heavy deluge - problem being a combination of a failed down pipe and a blocked gully).
I'd quite like to repair the hole with new laths and then plaster, rather than plasterboard.
What would be the best undercoat plaster to use? I have a quantity of browning left over from a previous project, and was wondering if this would do? Or would bonding be better?
