Law mower Briggs and Stratton
Discussion in 'In the Garden' started by kimbobimbo, 6 Jul 2013.
  1. kimbobimbo
    kimbobimbo
    12 Feb 2013
    12
    Thanks Received:
    South Glamorgan
    Country:
    Runs for about 3 mins then cuts out,new spark plug, stripped down carb & cleaned,cleaned out pipes, can hear a misfire just before cut out ,thanks
  2. Burnerman
    Burnerman
    7 Feb 2008
    23,620
    Thanks Received:
    4,621
    Northumberland
    Country:
    Its running out of fuel, basically.....is your machine the type with the tank below the carb, or the type with the tank wrapped around the engine - i.e gravity fed fuel?
    John :)
  3. Sponsored Links
  4. kimbobimbo
    kimbobimbo
    12 Feb 2013
    12
    Thanks Received:
    South Glamorgan
    Country:
    below the carb , tank comes off with carb assembly ,cleaned what I could!
  5. Burnerman
    Burnerman
    7 Feb 2008
    23,620
    Thanks Received:
    4,621
    Northumberland
    Country:
    These carburettors need to pump the fuel from the tank into a small holding chamber just below the main jet. To do this, there must be a connection of a rubber tube to the carb body - if this is missing / dislodged or whatever the carb can't pump.
    There is also a diaphragm between the carb body and the tank....replace this as its also prone to failure.
    If you have disconnected the carb from the tank, check the filters on the bottom of the two dip pipes for debris.
    John :)
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
