Laying a stone circle on top of existing concrete
22 Apr 2012
Hampshire
Hi all
I am a new registered user on this forum so hello :D
I would like to lay a stone circle on top of existing concrete, the concrete is in good condition but isn't very attractive to look at. The idea is to lay a stone circle and loose stones surrounding with stepping stones through.
What should I lay the stone circle on? Is it ok to just lay it on sharp sand? Then do I just brush in the loose self setting cement? Will this be secure enough or have I got it all wrong?
Thanks Chrissie
:D
Lay it on a bed of wet mortar, 5 sharp sand to 1 cement. (or plastering sand)
Don't point with a dry brush in mix or it will crack up in a year at best.
Use 4 plastering sand to 1 cement and mix it up so if you squeeze a ball of it in your hand water doesn't ooze out but the ball sticks together as one lump when you open your hand.
Then pack that in with a trowel and strike it with a jointing iron.
More info on pavingexpert.com
