hi guy
hit a problem....trying to cut last piece around the toilet ....have done the the rest with template and tile nippers etc....but last piece needs a hole in it...
have tried drilling tiny holes unsuccesfully...also have a tiles cutter with hole cutter but for some reason cant be cut right thru the tile...says cutter will cut thru 10mm tile ,tile is 9mm thick ??.....
have seen
CIRCLE TILE CUTTER AND GUARD £13 that fits to your drill are these any good./any one used one before can u use any drill with it
regards
geoff
have seen
regards
geoff
