I have a nice dry cement sand screed which I want to fit an engineered click wood floor to. The screed as expected has slight undulations of 2-3mm and in some areas I have used self levelling compound to bring it all fairly level. I doubt that using SLC over the whole floor will get it any better than it is.
I have ordered the flooring but Im now not sure which way to fix it down. I am leaning towards glue but the floor supplier has recommended underlay as I could have debonding and lifting especially with ufh. My issue with underlay is in some areas there will be no direct contact with the screed which effects heat transfer and will have hollows.
I would like to know what the ideal final screed finish should be before laying and what system to use.
I can find below, which should do the job, but can anyone recommend either:
GLUE: Laybond L16; Rewmar Polymer; SikkensT5; Sika T54 and Mapei P990
Underlay: Tuplex; Quicktherm; Accubond and X Protack
