Laying Solid Wood Floor ?
14 Jan 2012
Lincolnshire
Looking at laying Solid wood floor on Concreate Sub floor.
Not Sure of the Exact Proceedure due to so many variations.
Do i screed, or can i get away without screeding ?
Lay a DMP ?
Then Lay Underlay ?
Then How does the wood floor stick, due i then glue or do i then lay more adeshesive sheet over the Underlay.
Please Help ???
What i want is a floor that looks good, does come apart and does not sound horrible when walking on it.
Lots and lots of posts on here telling you all you need to know
................... if you bother to do a search
Lay a DMP ?
Then Lay Underlay ?
Screed or levelling is require if the floor is not level. +/- 3mm over 3 meters is the British Standard, but check the wood manufacturers recommendations.
DPM if the floor is damp. Check with a box hydrometer.
Underlay if you are floating laminate OR Glue if it's a solid but many other variations possible.
TT
