Laying joists
M
marsaday
I have plained joists for my new floor. they are 195 x 47 and only need to be 170's.
Anyway i have laid 2 joists now which are level at both ends with the previous joist, but starts to rise from there inwards. At the centre the joist is 8mm above the previous joist.
Is this normal or do i need to do something which i dont know about ?
Is there any way of taking out the difference. The only thing i have thought about is to plain them in situ.
20 Dec 2005
East Sussex
Chances are your old ceiling joists arent level and have deflected.. so yes normal.. get a spirit level and check the existing ones..
M
marsaday
yes the ceiling joists are deflected, but they are independant of my new floor. it is the new wood which has bowed (2 now).
It is level at both end where it meets the steel and wall plate, but in the middle rises 8mm above the other 2 new joists.
I have put this one in and will plane it down. I hope the rest are ok because it is a pain.
J
joinerjohn
You'd be very lucky to buy joists which don't have some degree of bow in them tbh. Always place them with the bow upwards in any case. ;) ;) ;) ;)
3 Sep 2006
West Mids
Carpentry is not engineering, and so bowed timber and non-perfectly flat floors and ceilings are normal
When the floor deck is down it will be hardly noticeable
23 Jan 2010
Sussex
Old joists seem to take up a bow with static load. I doubt they are still straight. Perhaps the new joists will develop a matching bow in time. Maybe you could try 22mm floorboards screwed to the joists to help line them up. Perhaps jack up the old joists before fitting noggins/bracing.
M
marsaday
the joist is bowed upwards and in the centre is 8mm higher, so i will plane it down a bit.
thanks for replies, good to know timber should be like this.
