Laying Karndean flooring
Hi
Good on you for having a go and trying it out. The area i need to cover is about 80m2 and there is underfloor heating under the chipboard.What primer did you use?
I am up in scotland but thanks for the offer to come and have a look.
I have about 2 months before i get the keys for the house so im sure i will sort somthing out.
regards
Chris
I will let you know how long it lasts if you're still here in a few years :). Thanks for your honest comments.
J
Just wondering how everybody has got on with laying the Karndean directly to chipboard? 7 years is quite a good test!
The simple answer is:
You can do whatever you want and run the risk of the floor failing
You can fit it as per the manufacturers instructions and significantly reduce or eliminate the risk and end up with a better looking job.
As a retailer, we would never fit direct to chipboard, and with areas like conmservatories and any area with UFH we would use the specialist UFH adhesives. If the floor fails, it's our responsibilty if it has'nt been fited correctly to the manufacturers instructions.
