Hello
I would like to know if I need to put any air vents into a laminate floor if I lay it over a suspended wooden floor.
It is ground floor, and there is air bricks from the outside to under the floor. I can feel a small draft coming from cracks imbetween the floor boards.
My concern is that by the time I put the under floor lining and then the laminate that it will limit air circulation and may cause a dry rot issue
Thanks in advance
Thanks in advance
