Laying laminate over uneven concrete floor with no DPM
4 May 2008
Lincolnshire
Hi all, I would appreciate your opinions / suggestions on the following.
I wish to lay some Classen Mega Lock laminate flooring in my dining room. The current floor has been stripped of the knackered Marley tiles which were down, and is now mostly bitumen adhesive with some patches of bare concrete. There is a slight difference between the height of the adhesive and the bare patches - no more than 1-2mm. I assume that there is no DPM, though there is a 1" wide trench round the edge of the room between the concrete and the wall - this was originally covered by the skirting.
Ideally I would like to find the quickest, easiest way to lay laminate in this room - I was thinking laying a heavy plastic DPM over the current concrete and folding the edges over into the trench at the edge of the room, then laying fibreboard underlay over this to even out the small height differences. I appreciate that my approach is something of a bodge, but is it likely to work in the short to medium term?
DPM has to be applied / fixed. Apply impact / heath insulation like Rockwool.. min 25mm http://www.rockwool.co.uk/products/u/2011.product/9857/building-insulation/rockwool®-slimfloor or http://www.rockwool.co.uk/products/u/2011.product/9905/building-insulation/rockfloor®
Rockwool Rockfloor is water resistant but requires a damp proof membrane (DPM) to protect against rising damp or high watertable areas when used below ground-bearing concrete.
Chipboard finish and whatever on the top.
http://rwiumbracouknew.inforce.dk/media/270095/rockfloordatasheet.pdf
