OK, I know laying linoleum is strongly disrecommended as a DIY job, but as a joiner I feel reasonably confident that I can make, and work from, a template accurately enough.
The setting: tiny 200-year-old stone-built terrace cottage, renewing the kitchen. Two-foot thick walls, sound concrete floor, no evidence of a damp-proof course in either, but also no sign of rising damp except in one spot by a party wall and behind a kitchen unit. And a square foot or two of penetrating damp by the back door, which may or may not dry out now that I’ve replaced the rotten timber threshold with concrete. The floor is only an inch at most higher than the concrete yard outside the back door.
The job: lay linoleum to the area not to be covered by kitchen units, roughly 2.8m x 1.4m. Tight budget – I want a sound and durable job, but don’t want to spend more than necessary to achieve it.
The story so far: I’ve taken up the old laminate flooring, which was loose-laid over a sheet of polythene maybe twelve years ago. All perfectly sound and dry. The concrete’s been screeded with self-levelling compound, and is sound and flat except one or two tiny areas where it hasn’t feathered out perfectly. Reasonably easy to fill, I imagine.
The questions: One – what would be the possible bad results if I simply loose-laid the linoleum over a polythene membrane? (I know lino should always be glued down; I also know that the loose-laid lino (not vinyl) that I crawled on as a baby was still doing its job quite adequately at least fifteen years later!) There’d be walls at both ends, kitchen units all along both sides, to stop it wandering around.
Two – if that’s a definite no-no, and since the floor is not 100% dry, I presume I should put a damp-proof membrane in. Would something like Sika Rapid Liquid DPM do the job? And could I glue the lino down directly over it, without re-screeding?
