Laying slabs
29 Oct 2007
Coventry
In the coming days I'll be laying riven slabs 600x600 on a dry sub base mix of 6:1 sharp sand and cement
Should i butt each slab up? or have a mortar joint? Is one method better than the other? Or is it down to personal preference?
If going with a mortar joint, what is the recommended spacing?
Cheers
I use 8mm
doubt you could ever get them levelled up if they are touching !
Would you recommend a 6:1 or 10:1 mix?
Also the 'dry' mix of sharp sand and cement is any water to be added whatsoever?
I've got plenty of hardcore/rubble so will be laying that down then wacker plate it followed by the weed membrane and then lay the bed of sharp sand/cement for the slabs
5:1 sharp sand/cement.
Wouldn't be putting a membrane down.
A properly consolidated sub base with a wet mix of mortar fully bedded with a minimum of 5mm joint to accommodate the grout.
