Hiya
I've bought some handy heat 10mm thermal substrate backer boards to fit under tiles in my kitchen (we're not having underfloor heating, but there is a void beneath the floor of almost 1.5m and its bloody cold!) however, my kitchen floor is made up of 2/3rds floorboard, and 1/3 concrete slab.
The manufacturer recommends fixing to concrete using an ordinary floor tile adhesive (preferably rapid setting).
I'm concerned about movement between the concrete and wooden parts of the floor - although this has never been a problem before (tiles are currentlydown on 15mm ply on the wood part, and cement on the cement part).
My question is: Some of the backerboards will need to be both on the wood and the concrete. Do I need to use a special membrane to cover the join where these to different floor materials meet? Or would a flexible tile adhesive do for the concrete part and normal screw downs for the wood part
Here's a spec
http://www.handyheat.co.uk/underfloor-heating/insulation.html
Thanks in advance for any help!
Faye
Here's a spec
Faye
