I'm extending my average-sized semi at the rear and side, and need to almost completely renew the foul drainage. My existing glazed vitrified clay drain starts part-way across the back of my house, where there is a 1m deep brick built chamber, and then runs under the boundary fence onto my neighbour's property.
I'm building up to 200mm from the boundary and across the whole of the back of the house, and the drains will need to serve my kitchen waste, which will be at the very front of the new extension at the side of the house. The drains will therefore have to go in an L shape around two sides of the house.
I will cut the existing pipe near the boundary (it will be exposed when I dig the footings, anyway), and use a clay to PVC adaptor, and then run 110mm plastic pipe with push-fit joins from there. The pipe across the back of the house will be under the finished floor, so I'll extend the run 1m or so beyond the far wall and site a chamber there.
Questions: The bathroom and downstairs toilet wastes will both enter the main straight section, and the only requirement for the section running at the side of the house will be for kitchen waste (sink, washing machine & dishwasher). Should I discharge those into an external gully at the front of the extension, and if so, would it be better to run a straight line of 110mm pipe as a branch directly to the gully location (under the floor), or instead, use the chamber to change direction and go around the extension externally, requiring another change of direction at the front. The ground is more easily accessible, but the run is longer and has an additional 90 degree bend.
The outlet from a bottle gully isn't very deep. Can I run a straight pipe from there (ie shallow), downhill to the junction with the other section, or should I turn the outlet from the gully sharply or even straight down, to a deeper pipe running at something like 1:40 to the next junction?
