lead lock lead to copper fitting. leaks
22 Nov 2019
Hi Everyone.
I had a lead lock leaking and decide to replace it. I know few years ago plumber also struggled to get it working and keep tightening it worked fine for few years.
With cold weather it started leaking again. I looked into it and decide to replace it.
First issue is that the pipe is 20mm external and there is nothing to properly fit it. The 3/8 5lb is way to small and the 1/2 6lb way too large. It slide in very easy no need for push and when tightened still leaks a bit .
How do you work with those issue? any paste or some sealant?
