Checking a leak in a friend's flat under the bath. It is on the hot supply side on a lead run of pipe and is coming from above two nuts (around 40mm/1.5 inch) that come out of a tee-fitting and below the swollen part of the pipe (I think this is the 'wetted' soldered joint). A few inches or so above and to the tap copper pipe is used but all of this area is dry.
Is it best to try tightening the upper nut slightly? - I am a bit cautious about this as this part of the pipe is obviously pretty old. Or should the HW be turned off and the nuts opened and the joints treated with some type of compound?
Thanks for any advice.
