I'm a complete novice to plumbing, but have a problem i feel could be easily solved - just after some advice.
I'm getting a slow drip from a component below a pump attached to my boiler, that I've identified as a pump valve (ball).
The water is seeping from what looks like an adjustment screw, at the top of the component in the picture attached. I've tried turning this a small amount in both directions - both result in more water!
What I need to know is whether I'm likely to be able to stop the leak using the valve, (eg which way to turn it) or whether I just need to get a plumber in (after the bank holiday weekend!)
Thanks in advance
Phil
Thanks in advance
Phil
