Good afternoon. I hope you are well. I have a problem and it looks like this:
BACKGROUND
* I have a hot water cylinder
* It is a Gledhill 1050x450 flexiseven combi tank made in 2009 with two immersion heaters
* The inflow of water is controlled by a ballcock in the tank.
* Unfortunately, the ballcock does not completely cut off the flow of water: instead, there is still a trickle coming out of inlet "D" (see diagram)
* Over several hours, the trickle fills the tank and leaks develop at leak "A" (see diagram) or, more rarely, at leak "B"
* This leak does (if not caught) cause damage (sodden, dripping carpets and mould).
* A friend of mine does DIY and has attempted to cure the problem by (I think) adjusting rotator cap "E" (see diagram) but this has not cured the problem: the trickle still flows (drips at approx 1 per second for hours) and the leak still develops.
* I want to cure the problem by adjusting screw "C" (see diagram) and moving the ballcock downwards, this forcing an earlier, more forceful cutoff. But there is limited workspace (access via tank cap "F") and this is difficult.
* I have searched the DIYNot wiki and FAQ for a solution but to no avail
MY QUESTIONS TO YOU ARE
1) What solutions would you recommend for this problem?
2) Could that solution be carried out by me (office worker, better with spreadsheet than tools, but - hey! - got a screwdriver for Xmas), my friend (semiprofessional DIY person) or by a plumber?
BACKGROUND
