So I'm currently living in rented accommodation in a flat covering the top two floors of a semi detached London townhouse-style building.
We've been getting some pretty significant leaking/damp that only exists on the shared wall with next door. It is bad enough that the leak actually drips from the coving on that wall in the lower floor.
The top floor is a single room that looks like it may have been some sort of attic conversion but there is no flat roof.
In terms of what I think might be causing this the only things I can think of are water leaking down the chimney but they are mostly capped and there seems to be too much damp too high for that.
There is flashing in place but I don't have enough experience to know if it's been put in place correctly. It does look a bit like the tiles are just placed on top of the flashing so water could be running under the tiles?
Does anyone have any experience with what could be causing this? I can post pictures later if that'd be useful as we have a small balcony I can see the roof from.
My landlord has been completely useless so far so any help would be much appreciated!
Cheers
Cheers
