Hi, we have a leak on the porch where it buts up to the house wall. The flashing looks ok where it is visible on the tiles but for some reason it goes in behind the ridge tile instead of going over the top (if that makes sense) and it is from here that it leaks. It has been sealed up in the past with silicone but this has dried out and has split. Its only a small leak and only happens when strong winds blow the rain against the wall.
What is it best to use to re seal it. I was going to clean the old silicone out and refill with lead mate and when this is dry give it a couple of good coats of roof seal which I have left from when I had a leak on the garage.
Does that sound ok?
Thanks Nige
Does that sound ok?
Thanks Nige
