Leak
14 Jan 2008
Cardiff
Hope someone can advise: The boiler went into lock mode because there wasn't any pressure. I released both values to increase the pressure to 1.5 bars and then turned them both off, so they are both now horizontal. however, now i'm having a leak through my light in the living room every time the taps are on upstairs...... can anyone help??!?
look under appliances for a leak, including waste pipes
I suspect that you may need to call Jones the plumber!
The problem is my bathroom is tilled so i can't see any pipes! I can't see how the boilers pressure would cause a leak!
If you think about it...
Where dd the water you replaced in the system go in the first place..?
A sealed system should not lose pressure.
