Hi all,
As a newb to plumbing I thought i'd start small by installing a bidet gun sprayer to the toilet cistern feed! It has been problematic. The only leak I have left (after several leaks) is between the T-valve and the entry to the cistern. Both are male 15mm. The cistern is your usual plastic job and the T-valve is metal. I thought I could use a 15mm female collar and just link the two together, but it hasn't worked. I think one of the problems is that there is no compression in the link anywhere; the two elements are touching inside the collar and I have used plenty (probably too much) teflon tape, but it is still peeing out either the top or the bottom of the collar, and I can't physically tighten anything any more without risking threading the plastic.
Any suggestions? Would a washer between the two inside the collar do the trick? Or do I just need to keep going with the TPFE tape!?
I've taken it apart and put it back together about 20 times now, so I'm coming to you guys in the hope of some solid ideas!
Any thoughts appreciated.
