On my old Glowworm Xtramax ! if it's only the hot water that is on (summer setting) then the nearest radiator mysteriously warms up when hw is drawn. And what has been discovered is that draining the boiler means also draining all the radiators which takes a long time, or shutting the radiators off.
So I am assuming this means that the 3-Way valve has gone ?
Is it important ?
Because these symptoms are not causing much inconvenience in general, the nearest rad is now shut off in the summer that's all.
Or is it a bigger problem that needs sorting out ?
Cheers
Is it important ?
Cheers
